gdutils
gdutils is a lightweight Python utility library. It provides tools for organized file management, clean logging, and quality plotting.
Installation
pip install gd-py-utils
Quick Start
1. Path Management (fPath)
Easily create paths relative to your script's location, ensuring portability.
import gdutils as gd
# Create an 'out' directory next to this script
out_dir = gd.fPath(__file__, "out", mkdir=True)
# -> /path/to/script_dir/out/
2. Data Management (Container)
A Container manages a directory and maintains a logical registry of your files.
import numpy as np
# Create a managed directory
out = gd.fPath(__file__, "out")
with gd.Container(out / "experiments/run_01", clean=True) as ct:
# Create file paths naturally (automatically registered by stem name)
data_file = ct / "data/results.npy"
np.save(data_file, np.random.randn(100))
# Access files later using their logical key (filename without extension)
print(ct.results)
# -> /abs/path/to/experiments/run_01/data/results.npy
3. Plotting Helpers (SPlot)
import matplotlib.pyplot as plt
# Context manager handles plt.show() or saving automatically
with gd.SPlot(fname=ct / "my_plot.png", show=False):
fig, ax = plt.subplots()
ax.plot([1, 2, 3], [4, 5, 6], label="Data")
4. Logging
Get clean, readable logs with minimal setup.
log = gd.get_logger()
log.info("Experiment started")
# [INFO] Experiment started
Features
- DataContainer: Persistent key-value registry for filesystem paths.
- TempContainer: Automatic temporary directory cleanup.
- Plotting:
despine,move_legend,get_color_cycle, andSPlotcontext manager. - Logging: Zero-config formatted logger.
- IO: Path manipulation helpers (
fPath).
